SLAM’ing - going through lots of liquid chlorine
splashpad
2,712
SE Kansas!
Good job! (You haven't had to add chlorine since Mon? That's a good sign, You're almost there!)
I wouldn't fuss with your TA right now, use Poolmath to dose muriatic acid to bring your PH down to 7.2/7.4 and then get back up to SLAM FC level. FC/CYA Chart (CYA/50 = SLAM FC/20, and test frequently and bring the FC back up when it tests below 20)
Be sure to keep brushing/scrubbing any of the areas that had algae, it's a tough organic to control! Follow all the steps in SLAM Process
kellyfair
4,765
Tampa, FL
Intex Krystal Clear
How often are you testing FC and bumping back up to SLAM level?
Steelkilt
Active member
May 21, 2020
30
Groveland, MA
Great thanks 👍 Not a drop of chlorine since Monday.
Reactions: splashpad
kellyfair
4,765
Tampa, FL
Intex Krystal Clear
Good, the more often you can test and bump, the quicker the SLAM!
splashpad
2,712
SE Kansas!
That's awesome! So yeah, dose muriatic acid according to PoolMath (7.8 to 7.2) and then test and add liquid chlorine to keep FC/20 until you don't lose any overnight! It takes patience, because that is the hardest test to pass, believe it or not! But once you do, you'll have easy, enjoyable management after this!
Steelkilt
Active member
May 21, 2020
30
Groveland, MA
At least I’ve got some clear direction and confidence moving forward, so thank you!
follow up question - I don’t have muriaric acid yet, but I’ve got some pH down and some low n slo from the previous owners. Can I use those since I have them on hand or not fuss around and go buy some acid?
splashpad
2,712
SE Kansas!
Honestly the dry acid adds sulfates which you don't want. I would highly suggest to go get Muriatic acid (usually in the paint dept of hardware stores) and keep it on hand, you will likely need it and it doesn't go bad! Just don't store it around metal! :D
Steelkilt
Active member
May 21, 2020
30
Groveland, MA
10-4! Metal is everywhere lol 😂
Where do you store yours?
splashpad
2,712
SE Kansas!
In an old kitty litter tote :D But anything plastic will work! Do not store it with the bleach either. For safety, it's best to use separate measuring containers that are dunked/rinsed in the pool water, so you don't get a dangerous reaction!! And wait 15-30min between each chemical addition. They are safe to handle, just be smart/careful about it ;)
Reactions: Steelkilt
IceShadow
2,609
Milwaukee, WI
I store my MA in a plastic seat/storage container outside near our pool deck. MA isn't affected by heat or cold and can be stored outside.
How does the pool look now? Any photos to share? If it's completely clear, no sign of algae, and you have no CC on your test, you could do an Overnight Chlorine Loss Test to make sure nothing is hidden in it and be all set. Otherwise like they said - adjust pH to 7.2 and bring it back to SLAM level. :)
Steelkilt
Active member
May 21, 2020
30
Groveland, MA
Crystal clear! Its raining now, but here's the photos from yesterdaypool_iOS.jpgpool2.jpg
