- May 22, 2021
- 195
- Plaster
- CircuPool RJ-60 Plus
Ok Thanks but assume that an SWG has a flow rate or the like to SLAM etc or does that require manually adding chlorine? Also looking at cost factors of bleach vs salt pellets, I assume salt is way cheaper and given the constant application of Cl- a whole lot easierYes- You would follow the saltwater generator portion of the FC/CYA Levels
The chances for algae are the same.
if you go near/ below minimum fc for your cya things will grow
The swg just takes care of the daily chlorine dosing for you vs you manually adding liquid chlorine.
