SLAM time....
Nope no drain and pump & fred running.... I mean, I am not going to complain [emoji23][emoji23]
Pool this morning:
Will test water in a bit... just woke up [emoji23][emoji23]
Christina
~14,000gal 14x30 IG vinyl, Hayward DE4820 filter (everything else is too old to read lol), TF100 Test Kit, TFPC method
Well I noticed fred was acting a little sluggish & tired, went and checked the filter and sure enough time to backwash... did that, added DE to recharge, cleaned pump basket and we are off and running again [emoji23][emoji23]
Poor fred, got his workout last night lol
Christina
Tested water... FC still holding at 13 lol Going to retest CYA later after water gets to room temp since it dissolved quickly yesterday.
Christina
Yup clear.... but just remeasured CYA... looks like it is at 60 [emoji849][emoji849] so going to up the chlorine now.... no wonder it has been holding at 13 [emoji23][emoji23][emoji23]
Christina
Dosed it up, brushed some more and will test FC in 30 min... then will hook fred back up to do his thing lol
Christina
Tested 30 min after adding and FC was 22 so dosed it up for 24 again [emoji106][emoji106] Test again in 30 [emoji119][emoji119]
Christina
Tested FC at 27 so holding at least :)
Christina
Yup brushed where he doesn't go this morning and took a toothbrush in that godforsaken cold water and brushed the return jet and skimmer really good... then while my hand was already freezing took my smaller stiff brush and brushed the ladder and under rungs as best as I could before the temperature actually started hurting my hand [emoji23][emoji23]
I will brush again later today as it gets warmer outside... really wish the sun was in the back yard [emoji23][emoji23]
Christina
Well! When you do something you do it right! Even when it hurts! It was all I could do to put my hand in to empty my skimmer basket!
Here is some :sun: to warm you back up!
Kim:kim:
It was so blasted cold lol I just held my breath and started scrubbing until I couldn't any more lol Will be happy when SLAM is done and then I can take the filter apart and clean it and recharge, get the water perfect and start the heater up for 4 hours a day lol
Should take forever to heat [emoji23][emoji23]
Christina
So FC still holding around 27 and took some more pics :)
From "shallow" side
From deep end:
I also brushed again... "in case" but I do not see any more at this point.
Christina
That has to be the fastest SLAM in the history of TFP! I would have thought your water would have looked a lot worse after you did all of the brushing.
So now here is the real test! How clear is your pool???? Can you see heads/tails on a coin at the bottom of the deep end? (how did is your deep end?).
Kim:kim:
Haha I couldn't see that on best days [emoji23][emoji23]
1. I wear bifocals [emoji23][emoji23]
2. The deep end is well over 8 and if you notice in pics it has major slopes on all sides including from the step
I usually just have to use Fred there on how clear it is... yesterday when I started it was really cloudy after brushing it all up but seems to be pretty clear now :)
I will do an OCLT tonight just to see but will probably hold it to SLAM a couple more days just to make myself comfy because that was a lot of algae lol
Wish the sun would hit it as that is a good way to see it shine
Christina
Well here is Fred about 5 min ago in the deep lol
Christina
Absolutely zero sun in the back yard except that one sliver earlier today lol come on May so I can have sun back here again lol
Christina
