Hello
The door to my skimmer area, that has a name that I can't remember, is missing the foam backing so the flapping door remains open all the time because of its weight.
1. Is this ok? I assume not since debris will flow out when the pump is off.
2. If not, what can I put behind it to get it to close again? Can I use packing foam, cut it, and get that door right somehow?
Thank you
Thank you
Thank you
Thank you
