Thanks for responding. The overflow is hooked up to a drain line. I cannot yet take a picture of the whole skimmer since the cover is still on (I take the cover off after the pollen ends). There is concrete around the skimmer for about 6 feet, so I can't tell if the ground is settling.
OK, thank you. I will try that. I found a picture during the install of the skimmer/overflow too. Is this the link for the AB compound you mentioned? I'm guessing the Single-Use Pouch ABP-1000?
my guess is the concrete has settled and the leverage on the overflow pipe cracked it. at least its up high in the skimmer and wont leak during normal pool water level. some type of goop will bandaid it, I forgot what brand was recommended by the pros
Your link is for epoxy gun type. Mine is for a putty type that you can roll in your hand to mix and apply. It is easier to apply the putty type compound.
