Shutdown several months and restart in spring.
DougJack
80
Jackson, WY
Hi, I have a 400 gallon hot tub in France - a Sundance, Lisbon. Everything has been purged, balanced, and is being sanitized with a SWG - disconnected the UV. No known problems. I am just looking ahead to the end of summer or possibly early winter and it will not be used for 6-9 months. Should I consider draining it or just turn off the heater and have someone I trust keep an eye on it? It does not freeze here. I tried to search for people doing similar things, but I couldn't find anything that looked definitive. It seemed pretty clear that if you can't get all the water out you are in the bug hosting mode....I'm sure others have found a "best way" to do this.
Our manufacturer and installer warned us not to fully drain for winter or it would void our warranty. I put mine into economy mode and keep chlorine tabs floating through the winter and adjust TA and PH as needed when I can get to it in the snow drifts. We don’t use it in the winter.
Thanks - I notice you have a SWG and a pool. Was your wintering strategy for that setup or a hot tub?
Doesn't help your question, but excuse for a grandkids-pic ;)
We run ours all winter, because the hot tub is best when it's 15F out, and the snow melts just before it hits the water :)
Reactions: JodieM
Why would you disconnect the UV? It helps the SWG, and doesn't harm anything.
That really made me think - thanks! My original experience when I first started taking over the hot-tub was that the FC collapsed rapidly and I thought that it was due to the UV and didn't dig in further. Since then I have learned a lot (thanks to this forum) and some personal exploration. I'm likely going to turn it back on in the next week or so. First I am turning off the SWG and with the UV off and no bather load am going to get a 12 hour baseline on the FC loss. Then I hope I get good enough weather to get out to turn the UV back on and see what happens with the SWG still off.
There are some numbers that I can't reconcile though, and maybe you know more about. The 24/7 pump runs at 35 gpm which means to me that there are 50k gallons/day or 126 "passes" of water through the UV tube. The unbound FC (close to 5% of FC total) supposedly is reduced by 50-90% per pass. The bound FC is roughly 20X more resistant, but there is 20X more of it, so the loss per pass on that basis is 2 * .05 * .5 * FC total (4 ppm estimate) = .2 ppm per pass. Obviously in 20 passes with no HOCL source all of the FC would be gone. Maybe the UV dose is much much lower than some estimates?
