I have a fountain that I think has a small leak and I would like to shut it down. It has one drain and a return that somewhere forks out to two pipes.
If I just turn off the fountain I am concerned that the water will sit in the pipes and grow algae. I have a 4hp shop vac and I was wondering if I could just put that in the fountain returns and blow the water out. If I did that though I dont know where the water would go. So i was then thinking I would take off the jandy valve at the return. If I can find some way to create way to make it tight so the air wont leak out then I could blow the water out to the fountain. However, I would then have water in the pipes from the fountain to the pump.
Soooo, not really sure what to do to shut this fountain down and get the water out of the lines.
Any help is appreciated.
