Pool kicks off during freeze mode
Karenself1959
3
Houston
My Polaris pool has a freeze mode that kicks in around 35 degrees. I keep my slide on when I know it will be cold. When the temperature drops and the freeze mode kicks in, the pool , slide and feature fountain all come on as they should. But now I am noticing that after a few cycles the pool goes off and only the fountain will be running. What could be causing this issue?
What model pump do you have?
What model freeze control do you have?
If you have a spa, most automation systems will automatically switch between Spa and Pool mode to keep both lines flowing. What type of automation system do you have?
