- Apr 11, 2024
- 70
- Vinyl
- Pentair Intellichlor IC-40
Doing a big L shaped vinyl inground pool. I dont really understand if i'm supposed to put in a sump pump. i had to leave the hole dug and open over winter and we got some major rains here on the west coast. I thought my ground water was higher, but even with the big rains, there was rarely water around the outside edge of the pool. it did fill up after the rains though and would take a bit to dry back out. attached is a photo if it helps.
also, what do i do for a sump pump? am i just kind of running a 1.5" pipe under the drain lines and surrounding with some gravel/drainrock under neat the drains... then running that pipe out to the concrete patio so a pump can be attached there? the pump itself doesn't go under the pool i assume?
