Greetings All:
My pool dig is around the corner. I want to educate myself on hydraulics as much as I can. On this journey, I created a 2D plumbing schematic for my pool. Please refer the attached PDF document. Here are some details:
Integrated infinity SPA (360 deg. spill over) 12" raised from pool (will sit on next to shallow end sun shelf) of 8' X 8'
6 therapy jets
Dedicated Main drain
2 Floor Returns
QUESTIONS:
When I'm in pool mode, I assume water is delivered to SPA for spill over. How do I do the plumbing for this ?.
At present I connected the 2 SPA floor returns to the 2 Pool floor returns. Is this correct?.
Is my Check Valve placement on IC60SWCG is right?.
Am I missing anything else?
Did I make any mistake in the plumbing connections?
Rain Fall Water Feature:
I've a dedicated pump for this feature with appropriate suction line.
However, when I'm in SPA mode I want to run all the 5 LED Bubblers to come on. So, I made a plumbing connection to this pump. My question is do I need to have one more Main drain at the pool or the 2 side suction is sufficient enough for Rain fall water feature as well as 5 bubbler actions?.
Equipment: ALL PENT AIR EQUIPMENT
Both Pumps: Intelliflow XF/VSF
Filter : DE 60
IC60 SWCG
400K BTU NG Heater
Automation:
INTELLI CENTER I10PS PERSANOLITY KIT with Load Center
Your feed back, suggestions are much appreciated.
6 therapy jets
2 Floor Returns
QUESTIONS:
Filter : DE 60
IC60 SWCG
400K BTU NG Heater
Automation:
