It should at least be marked on both ends.White wires were used as the 2nd leg sometimes.
Someone might find the other end and assume that it is a neutral that they can use for some reason.
I agree with you, and will do this from now on.With every test with every wire that gets removed you should check the pool. Testing for voltages is good but testing the annoying voltage when a parameter is changed is better.
I always measure with the deck wet, and I double check using the deck anchor for the cover.The water to deck reading is difficult to establish a good deck contact.
You probably need to find a way to make good contact like wetting the deck and then putting a metal plate on the wet deck.
I don't believe there is any way a hot could be hooked to a neutral and still hold. Neutrals are tied to the EGC at the panel and would instantly trip. Also it would make a direct short across the transformer which would also trip the breaker.Another white wire used for power.
At least it is taped black on this side.
The other side might not be taped black, which risks someone using it as a neutral.
Of course. When I’ve seen it in the past they usually taped the last inch with electrical tape so the end was ‘black’ on both ends. This one evidentally didn’t care.t should at least be marked on both ends.
That GFCI goes out to the pump and the GFCI outlet.What does this GFCI go to?
Does your PowerBlaster power monitor show you the voltage and current on both legs of the power?
If yes, is the voltage on each leg the same?
This makes me want to scream because of the all inconsistencies in the panel. Multiple labels are incorrect because of all the additions over the years. I'll need to find out where this goes.Another white wire used for power.
It looks like it has a neutral. What does the neutral go to?That GFCI goes out to the pump.
Most likely, it isn't a problem because it would instantly trip as was pointed out.I'll need to find out where this goes.
So this one has the pump and the GFCI outlet outside. The neutral is screwed into the one pole with the Test functionality, and then the second white under it is running to the ground bar.What does this GFCI go to?
General contractor BS. This is wired to a secondary HVAC unit. It has more black electrical tape going up the wire apart of the same wire run as the hot.Another white wire used for power.
You are correct, the same set of troubleshooting processes needs to be followed with thorough documentation.You work IT right?
Do you fix computers?
troubleshoot networks?
It's the exact same thing!
A process of elimination. Troubleshooting skils are all the same no matter what you're troubleshooting. You may think oh! it's over here only to find it is not. Now you have one less place to look. Go to the next place if it's not there move on and now you know two places it is not.
Take notes record voltages at the pool and at the place you are testing. See a pattern? work on it. Running out of ideas walk around looking over every little detail of the pool and anything electric. When done do it again you may have missed something been thinking of another project and missed it.
Troubleshooting is not always and most times not easy and takes patience and perseverance.
Can you put the pump on the breaker by itself and feed the GFCI outlet from a single pole breaker?So this one has the pump and the GFCI outlet outside.
The wires look too small for a HVAC unit.This is wired to a secondary HVAC unit.
You don't normally have 120v outlets on a 240v circuit to a piece of utilization equipment. The pump circuit is sized for the motor and when tossing random outlets into the mix you no longer have control over what runs on that circuit.So this one has the pump and the GFCI outlet outside. The neutral is screwed into the one pole with the Test functionality, and then the second white under it is running to the ground bar.
This is normal IF run in romex. If in conduit then a hot can not be white taped black, it has to be a color.General contractor BS. This is wired to a secondary HVAC unit. It has more black electrical tape going up the wire apart of the same wire run as the hot.
I hooked it up to oscilloscope very quickly, it was intermittent voltage and frequency. Then.... It started to rainThis entire thing looks sketchy.
You have a bunch of loose wires, dirt and corrosion.
It would be interesting to see the voltage and waveform on the scope of the power from the phone company.
Lol. It’s 40 year old outdoor copper. It should be Statue of Liberty green and look like wire spaghetti from all the times it’s been played with / modified. All things considered it’s not too bad. (Although certainly not ‘neat’ or showing worker pride).This entire thing looks sketchy.
