I read a few articles on air leaks, and also watched a a few youtubes on the subject. First, I see no air bubbles in the pump filter basket when the machine is running. I don't hear any hissing around the system, either. However, from time to time, and usually after a start up, my return lines will temporarily hesitate, obviously clearing airgaps in the line. Once they are cleared that issue ceases.
A youtube guy used smoke to detect a leak at connections. Obviously, that can only work if there is no wind in the area. Car tire repairers use soapy water to detect airleaks, looking for bubbles. I will try the latter.
If somebody could explain to me the dynamics of priming and water recovery, I might be able to figure this out. What causes the difficulty? Is it water in the return lines up to the skimmer and main drain valves that runs back to the pool, or water in the filter and the pump that drains back to the pool? Assuming a check valve were placed before the pump and after the skimmer lines what function would holding the water in the pump play?
Most importantly, what function does the air relief valve on the filter play in priming? Pentair says to open the valve, and wait for water to shoot out. But where is this water coming from because I have seen water expelled before the pump priming is complete. Is this water in the filter sitting in the bottom that has to work its way up for priming to occur?
Thank you for explaining this.
