Semi inground pool construction
The company has suggested she install mineral system. What’s your thought on her installing this system?
Don't.
Copper and silver minerals accumulate in the water and can stain the pool. They provide no sanitizing benefit.
No to the Frog as well - it is advertised as mineral based to lower the chlorine use. A salt water chlorine generator is what she wants. An appropriate level of chlorine per the Cyanuric Acid level and other water levels is the way you sanitize the water and keep algae out.
Reactions: Everett_88
There are no new things beyond a SWG.
All the "new things" are marketing gimmicks designed to extract money from pool owners.
No frog system.
Thank u I felt that was the case with this company but wanted to make sure! I told her find a company that will just install her a pool and filtration and that’s all. This particular one keeps trying to sell this mineral or frog system and refuses to do anything different. Thank u for ur help!
