Stoopalini
- Jun 8, 2020
- 590
- Plaster
- Pentair Intellichlor IC-40
No auto fill appear to be no leaks. I watch the level and doesn’t drop quick. Only after rain thru overflow.Do you have an autofill? Could you be losing water through a leak and not know it?
I may be still climbing I have my sell set high to shoot for 5-7.
That’s true they wouldn’t know. Before this all started I ran at the level suggested for cya. Once it started dropping I could not keep up. It would drop then come back. At one point I was running my system at 85% with a level of 4. I will try slam and if it breaks it breaks. If there’s something there I guess it will be fixed. Kids will be mad they can’t swim for days the first summer with pool which is exactly what I didn’t want to happen. It is what it is at this pointI feel your pain. However, you are still mixing and matching advice. Many of us have had similar experiences. Let me give you this last piece of advice. Get a bunch of LC from the pool store, I live in Florida too, and its cheap. SLAM your pool for two days. You will not void any warranty doing that and it will not cost a lot of money. How does the pool builder know what level your FC was a week ago, he has no ability to test that, nobody does. What do you have to lose. Then do an OCLT, but again SLAM first. Then for two weeks run your FC hot. Run it at 15, well below SLAM level but high enough to kill any residuals. You will need LC and you will not be able to do that with the SWG alone.
Its your pool, do what you want. Thousands of people have used this methodology and it works for them. I am one of the converts. I struggled for years, and hated my pool that had all this issues you had. Now I have none of those. Am I perfect, no. I made a mistake this year and got some black algae. I went back to my the basics and followed the great advice given here, and my pool looks amazing. My pool gets full Florida sun all day long and I keep it looking great and have no issues maintaining FC.
Now, my pool is hot, and I get a LOT of rain so I have to add CYA quite often. No problem, I buy it off Amazon for $2 per lb and I test CYA often. I stock up on LC from Leslies whenever they have a coupon and supplement my SWG to make sure I keep my FC on the high end of the range. All my neighbors and friends are envious of how my pool looks.
Rule #1. Amateurs run their FC towards the lower end of the range, and the experts here run it on the high end of the range. Guess who’s pools look better?
The SLAM Process does not prevent swimming in the pool. If you cannot see the bottom of the pool, that prevents you from swimming.Kids will be mad they can’t swim for days the first summer with pool which is exactly what I didn’t want to happen.
Yeppers I understand that. There is a difference from yesterday when I was 8.5 until today at 13. I added less than what was recommended for acid as a precaution. Trying to keep PH around 7.4 or 7.6. To see if helps with flakes. Rain has been keeping lower lately.Just so you know for the future, a PH reading when the FC is above 10ppm isn't accurate. So the 7.8- 8 can be different in actuality. Test again only after the FC gets below 10ppm.
