Good evening,
Second time coming in for support. After battling trying to maintain chlorine levels it seems like I may have that fixed but now seem to have a different issue. Pool always stays fairly balanced but struggled with chlorine levels and we think it was a glitch in the salt system. I have cleaned the cell and was finally holding chlorine at about 3.5-4 for a week and then dropped to 1.5 with no adjustment. Had rain so I added salt and stabilizer and was in track. Yesterday chlorine hovering around 1.5-2, today I was at 1. I ran out of stabilizer test liquid so I had to have the pool store test it and I got more fluid while
There. They tested it at 15. So when I got home I tested it myself and got 20. My question is how often should I be adding stabilizer to the pool? It seems like I have to add more than what I would expect. I have added at least two gallons in a 4-5 months and just had to add 3lbs today.
I know you will want test numbers and I am using the TFT kit
FC-1.5
CC-.2
PH-7.8
CH-375
TA-90
CYA-20
Should I be adding every couple months or twice a year or what? I don’t appear to have a leak, no auto fill, salt level stays pretty steady, haven’t had to add that much salt since it was new maybe 40-50 pounds total in about 9 months. I am at a loss.
FC-1.5
CC-.2
PH-7.8
CH-375
TA-90
CYA-20
