Started SLAM four days ago. Rather than running through a lot of FAS-DPD reagents and the time involved in doing that test, I know from the last couple days of testing every four hours that I need to add 9 quarts of 12.5% solution spread out throughout the day to stay at or slightly above the FC level for my given CYA level. I figure until I can see my feet it's probably reasonable to just continue doing that. And then just do FAS-DPD after dinner as a sanity check.
Also, I'm running the pump and bypassing the filter, just to circulate chemicals, as I figure the filter doesn't kill algae, the chlorine does. Once the green goes away I'll reengage the filter.
Seem reasonable?
Seem reasonable?
