Last summer season I had an independent pool guy maintain the pool, he did a great job, water stayed clear, didn't need much in the way of chemicals. I watched him closely and learned a lot from asking questions. I've spent a lot of time reading these forums so I have an idea of what to do this year. I had him open the pool and get it started, the water is clear and looks good. This forum has already saved me time and money by not getting "poolstored".
It's a vinyl liner pool, rectangular, shallow and deep ends, estimate about 20k gallons. I'm chlorinating with trichlor tablets, I know this isn't ideal but it will do for now. Last year the pool guy used a Taylor test kit in the blue case and said things were pretty good most weeks. The plumbing is relatively simple compared to some pools on this forum...one variable speed pump, two skimmers, one set of two drains on the bottom, two returns in the shallow end.
I don't have any maintenance equipment so I've ordered a vacuum head, pole, vacuum hose, brush, net, and a vacuum plate to connect to one of the skimmers. I ordered a TF test kit so I can see what's going on with the water.
Tasks completed Summer 2022:
Removed rusted out gas heater, plumbing was bypassed before I moved in.
Set schedule on variable speed pump instead of being controlled by time clock.
Remove Polaris booster pump and connect plumbing to bypass. Cleaner did not come with the house. I connected and tried the booster pump, it ran for 30 seconds before making a dreadful noise and started smoking. I put an eyeball return in the cleaner return for now.
Removed broken check valve from return path, found it was severely restricting flow and causing high pressure in the sand filter and the multiport was leaking from the sight glass and out the waste port.
Installed new sand filter with multiport, new sand. The returns flow a lot better after removing the check valve and replacing the filter.
To do Summer 2023:
Install GFCI breaker for pool pump
Get the light working - new bulb and gasket, verify light is GFCI protected
Get a salt system
I'm pretty new to pools, how am I doing so far?
To do Summer 2023:
Get a salt system
