Can I get my pool clear with 3yr old sand? I have a green pool. My ex has it green and I’m watching it for the week and want to have it clear for when she gets back. I will begin slamming tonight
As mentioned it’s already a bagillion years old- it may be in need of a deep cleaning if potionsCan I get my pool clear with 3yr old sand? I have a green pool. My ex has it green and I’m watching it for the week and want to have it clear for when she gets back. I will begin slamming tonight
The filter will not clear a green pool, especially a sand filter. Green=live algae. First kill it then it can be filtered out. May need a bit of help with a handful of DE or cellulose fiber.Can I get my pool clear with 3yr old sand? I have a green pool. My ex has it green and I’m watching it for the week and want to have it clear for when she gets back. I will begin slamming tonight
Now it is a combination of keeping the chemicals at proper levels and allowing the filter to remove all that dead algae. Just keep it running.View attachment 517740View attachment 517740Doing Slam process and this is where I’m at. I was scrubbing daily and dropped the brush in the bottom of the pool!!!! I’m planning to get in and do a good scrubbing today. I tested this am and FC was in slam level. Do I just keep fighting the good fight? This is where we got it to previously and it wouldn’t clear
Yeah I think I have a pretty good one it’s only been since SundayDepending on the size and quality of your sand filter it can take quite a while to clear up. I had a 13" XtremePowerUS Sand filter (for 6K gal) that had terrible laterals (none actually just a cone - see picture) and could not get the pool clean. After 3 weeks of SLAM I was finally able to see the bottom. I upgraded to a Pentair cartridge filter and the pool was crystal clear the next day.
Ok thanks! I have been doing chemical in the morning and evening. I don’t add chemical when the sun is out correct?Yupjust keep fighting the good fight!
Maintain slam level as often as you can. The more you do this the faster it will go.
Brush, brush, brush, run your bug too!
If you have steps/ladder get them out asap & clean them inside & out. They are known algae hotels. If they have sand inside get that out & find another sealed way to weigh them down.
Here’s the how to on the de
Add DE to a Sand Filter
A clean pool filter will increase the efficiency of your pool! ... your filter are to backwash it, clean the manifolds and grids, and add new DE.www.google.com
Nope, you really want to raise to SLAM level as often as you can, for example, every two hours. If you are gone all day, do it in the morning before you leave, again when you get home, and again at bedtime.Ok thanks! I have been doing chemical in the morning and evening. I don’t add chemical when the sun is out correct?
The more frequently you MAINTAIN slam level the faster you will achieve all 3 end of slam criteria.Ok thanks! I have been doing chemical in the morning and evening.
Incorrect- MAINTAIN slam level as often as possible.I don’t add chemical when the sun is out correct?
Do I start try to balance while it’s still cloudy or keep slamming until clear. It seems chlorine is steady but haven’t checked everything else due to high chlorineNow it is a combination of keeping the chemicals at proper levels and allowing the filter to remove all that dead algae. Just keep it running.
Again, a handful of DE or cellulose fiber will go a long way toward clearing it faster. May take several filter cleanings and the addition of the DE to get the job done.
Keep with the SLAM Process until you pass all 3 end of slam criteria.Do I start try to balance while it’s still cloudy or keep slamming until clear. It seems chlorine is steady but haven’t checked everything else due to high chlorine
