Hi all; New to forum! Hope someone can help me out. I have an in-ground 26k gallon pool. 24" Sand filter with new lateral and pipe assy. New 2hp single speed motor. Pump rebuilt (seals were leaking) Maintains constant 22psi on pressure gauge...NEVER EVER CHANGES
Problem is ever since had pump rebuilt and motor replaced, water is ALWAYS cloudy. Before the pump and motor work, everything was fine. Glass media was just replaced 3 months prior to pump/motor repair. I've tried to floc and water was clear after vacuuming. Then it gradually got cloudy again. Water tests show good levels on pH, chlorine, etc... but still getting cloudy and green. It's like it's not filtering ever since pump/motor work.
Is it possible to have too much motor?
