- Jan 2, 2018
- 563
- Fiberglass
- Pentair Intellichlor IC-60
The right side after the initial electrial:
Added jet air line (lt blue), some irrigation valves (left one is pool water filler), and prepped pipe entry/exits:
Added Returns/Jet plumbing & SWG:
Closer look at the plumbing:
Replaced SWG with dummy & connected Returns module:
Doing static water test now. If ok, run the pump and pray for no leaks. While waiting, going to scoop pool since the string of 100°+ days has caused some leaves to fall & don't want to start SLAM with 'em in the pool.
Still have some pad work (bonding wire, wireless setup, couple of deck boards to the filter to make it easier to walk, roof/shade, and build manual vac module, but the list is getting smaller.
