Still hoping Jimmy will comment about previous post, but after my reading, now think there's a typo in
If it was inspected it should have more than 4 sweep 90s that's code.
Think it should be
no more than 4 sweep 90s. That I understand.
New light wasn't delivered Friday as scheduled. Maybe Tues?
Originally planned to start lowering water level today, but just plain tired, so spent most of the time researching. So much about pulling pool light cords on TFP & the web.
So now I know exactly what to do.
1) Lubricate the cable with soap because using wire pulling lubricant mixed with chlorine causes problems later
but also saw
Lubricate the cable with wire pulling lubricant because soap cakes up & causes problems later
or
Lubricate the cable with something like water soluable KY jelly (hey, I've got a ton of surgical lubricant here!)
or
Blow air through the conduit to clean it out
or
Blow soapy water through the conduit to clean it out
or
2) Use silicon to seal the cord to the niche and j-box because it's code
or
Use potting compound to seal the cord to the niche
or
Don't seal the niche unless it's leaking 'cause it's expected to have water in the conduit
Have seen niche bonding wire as must be 8 ga
solid and must be 8 ga
stranded. Solid for equipment, but stranded makes more sense to me here, but...
My day for conflicts I guess.
