- Nov 12, 2017
- 12,639
- Plaster
- Pentair Intellichlor IC-40
More lube will not solve it. If it doesn't do it's job with the right amount, it won't do it better with more. One thing to try: wipe off the excess lube, from ring and track. Put a little on your fingers and thumb, and gently pull the ring through your fingers. I pull, Allen here says only push, so as not to stretch the ring out, but I pull for this reason: you're feeling for any knick or cut or bump or distortion in the ring (you could miss a cut if you push). If you find any, that might be the culprit, and you replace the ring.
