Filter news:
Started it up "as is" from last trial on Friday
Took it apart again. This manifold spring assembly & a screen top for the center tube inside of it was what I was missing the first time. Result was that even though I tightened the band enough to bend the bolt, the band was loose enough that I could still spin it.
Bent bolt seems to tighten ok yet.
Recleaned the track and band. Took most of the lube off of the o-ring and reassembled marking lid & ring positions. Yeah, had some duct tape and pvc in place just in case.
Started in up & ... no leaks.
Took off pvc & duct tape and set start/clean indicator.
Ran it for 15 min or so, then couldn't leave well enough alone.
Saw a few leaves & thought there was enough water to switch from my sucker pipe to the skimmer, so turned Jandy to change source. Nope, not enough water. Should have turned pump off at that point, but turned Jandy back to my sucker as the source & went to turn on hose bib to add water in case too much had been lost in the sucker. Hear a
pop and the filter lid is loose.
Will check it over later.
