Retrieving the sample
Niteowl
165
Pinellas Park, Florida
Does anyone use any kind of tool to help you retrieve the water sample? from what I have read, I am supposed to retrieve the sample from about 17" below the surface. this requires me to get down on all 4 to do it. I am getting older and this is rough on the knees and sometimes hard to get back up. I have seen some type of pole that the jar can go on to retrieve it, does anyone use a tool for this?
Jimrahbe
21,218
Bedford, TX
Owl,
In the winter I just use a small PVC pipe.. Stick it in the pool and put my thumb over the end and pull it out. Taking the thumb off releases the water..
Not perfect as it leaks some, but it works to fill up my test bottle.
ajw22
24,880
Northern NJ
Pentair Intellichlor IC-60
From @YippeeSkippy ...
If you want a simple easy to use way to get a good pool water sample out without touching the water yourself--> use a piece of 1/2 or so PVC like a pipette. I have a piece that's about 3 feet long that I use. I just thumb over the top end before putting it into the water, then release my thumb and the water displaces the air inside and I again cover the top end to "hold onto" my sample water as I remove the pvc tube and drop my sample into a big plastic cup. Just like you do with a soda straw, y'know?
