Resurface plaster pool with Fiberglass composite?
fern88
0
Jul 27, 2012
10
Hello TFPers,
I’ve started collecting quotes to resurface my plaster pool here in Southern California. It’s a 25,000-gallon pool, and so far, the estimates I’ve received are around $19,000 for plaster and $22,000 for either pebble or fiberglass composite.
The scope of work includes
- Resurfacing
- New tile,
- Splitting the drains
- New expansion sealer
- And startup
I plan to keep the existing coping. From what I can tell, the plumbing is copper, and one contractor mentioned that fiberglass composite might be the best option since it would prevent any copper from leaching into the surface.
I’ve heard of pre-made fiberglass pools, but not fiberglass composite surfaces.
I’m mainly wondering if these prices sound reasonable for Southern California, and whether fiberglass composite is a smart choice compared to plaster or pebble. Is maintenance harder than pebble?
thx
Hello TFPers,
- Resurfacing
- New tile,
- And startup
thx
How old is this pool? Copper would be an odd choice for plumbing in a pool. What’s makes you think it’s copper?
Do some research on “hybrid” pools. They are fiberglass walls with concrete bottom. They are a big pain to deal with later on if repairs are needed.
Maybe consider removing the main drains altogether and replace the remaining plumbing with standard PVC?
I think it was built in the 70's. We bought it in 2010. If you look at the last photo, you can see the metal pipes going into the ground.
I see it. How bad would the damage be to the budget to replace those? You can safely remove the bottom drain all together by just filling it in instead of adding a second drain. The drains are optional and don’t do much anyway.
Good question, I think around 7k to repipe both spa and pool.
I’d pay the $7k vs using fiberglass in the refurb all day long.
Having the old plaster chipped out like mentioned above before applying new is also a very wise idea. Almost guarantee they won’t want to do it though and it’ll add another $5k onto the job.
Thanks for the info, steps on the quote for states the following steps for the surface. Is Roughening the same as chipping the plaster or less deep?
PLASTER:
Draining the Pool and Spa
Surface Cleaning and Roughening
Repairing Any Cracks or Damage
Applying Bonding Agent
Mixing Plaster Material
Applying First Coat of Plaster
Applying Subsequent Coats of Plaster
Smoothing and Shaping the Surface
Curing the Plaster
Acid Washing (if necessary)
Final Surface Finishing
Leak Testing
System Integration
Final Inspection
Cleanup
Pebble:
Mixing Mini Pebble Material
Applying Mini Pebble Finish
Curing the Mini Pebble Finish
Leak Testing
System Integration
Final Inspection
Cleanup
FIBERGLASS COMPOSITE:
Applying Primer or Bonding Agent
Laying Down Fiberglass Matting
Applying Fiberglass Resin
Curing the Fiberglass
Final Surface Finishing (sanding and
polishing)
Leak Testing
System Integration
Final Inspection
Cleanup
PLASTER:
Curing the Plaster
Leak Testing
System Integration
Final Inspection
Cleanup
Pebble:
Leak Testing
System Integration
Final Inspection
Cleanup
polishing)
Leak Testing
System Integration
Final Inspection
Cleanup
Roughing is not the same as removing all of the old surface
Reactions: fern88
