The plumber/electrician/pool expert finished wiring the OmniPL today. He had the control set for the spa to spillover anytime the control was in the pool mode.
Said I have two options:
Pool mode (spillover constant, drains closed, pool and spa returns open)
Spa mode (spillover off, spa returns on, pool returns off, spa drain open)
I told him having the spillover constant when in pool mode was unacceptable. I did not want to listen to the noise 24/7 and it raises the PH. He says he's been in the pool business for 20 years and he's never heard such about aeration raising the PH. Also says 100 percent of pools with spas spillover all the time. I told him the first pool the builder showed us had the spa off and the bubblers were running on the sunshelf.
So my question is, I have a three way valve that I want to be able to operate 180 degrees from spa returns closed to pool returns closed and variable in between. He says that is impossible. So for now, I manually flip the toggle switch to do what I want but there should be a better way. This is important enough for me to get rid of valve automation.
Another known issue, the blower does not come on when set on with the display. I can hear a relay click but nothing happens. I turned on the booster pump and that works.
Pictures below show the wiring, the equip pad, and a conduit strap he left hanging that says "the plumber was here". PVC glue was spilled on the kool deck and left and he was going to take the heat pump anchoring straps with him. I had them left so the builder can put them on so some strong winds doesn't rip it up from where it's sitting.
Salt cell installed but no one has added salt. The picture of where my fingers are holding the two black wires are where the blower is connected to the relay. Have not looked at the manual to see if this is wired correctly or if it is programmed for the correct relay. The plumber seemed to be in a hurry to get out of here.
The wire gauge from panel to control is not rated for 100 amps and the cable type is not for this application per code.
