Hello all
I'm looking to take on a bit of a project to restore / rejuvenate the sandstone edging and concrete paving around my pool, and hoping for advice form people have may have carried out similar projects. The current issues I'd like to rectify are:
1. discoloration of sandstone
2. damage to sandstone (water weathering)
3. discolouration to paving
4. poor sanding between paving, leading to weeds around pool.
from research on this forum, I believe the following process may suffice.
1. Use a strong mix of regular pool chlorine in a spray bottle to kill the mould / organic matter in the sandstone and surrounding paving. I assume that chlorine is the best chemical to use as you want to avoid herbicide run off into the pool? Any other recommendations on this? Will the chlorine damage or discolour the sandstone or concrete pavers?
2. Allow chlorine to work for 2 to 3 days.
3. Pressure clean and scrub sandstone and paving
4. Floc and vacuum the pool to pick up all of the run off and dead organic matter
5. Seal the sandstone pavers, using a specific pool and sandstone sealer.
6. Re-sand the concrete pavers, with a hard setting sand
7. Seal the concrete pavers with a product suitable for around pools, but not a pool specific product. Note I am considering a wet look paver sealer to rejuvenate.
I'm hoping someone with experience can comment on this process, and let me know if there is anything I should change, or any tips and tricks.
Additionally, for general upkeep of paving around pools, specifically control of weeds in the paving, or surrounding garden beds, what do you all generally use to avoid herbicide run off into the pool, or is this something I don't need to worry about?
Thanks in advance for your help.
