- Aug 23, 2017
- 109
- Plaster
- Hayward Aqua Rite (T-15)
I’m about to plumb in my SWG and in the process remove the inline chlorinator and add a tee for a threaded insert for acid injection.
My question is in cutting out the chlorinator will there be sufficient “flex” to pop the new pipe in between the valves or do I need to remove the whole section to past the elbow past the valve?
I just want to be sure I have all the needed fittings on hand before I make the first cut so I’m not having to run out when my plan falls apart. I did find a 2” socket saver at the local hardware to get the old pvc out of the valves.
Picture of the piece I plan to replace is circled.
