Hi-
Thanks to everyone in this forum for the help. I got help awhile back boring out PVC from a union at the pump last year and it was much appreciated.
I wasn't sure if this belonged here or in the pool cleaner forum.
I have a leak at the top fitting (outflow) on the my polaris booster pump. A trickle when the main pump is on but a full on spray if the booster pump is on. The motor is also loud so I bought a new pump but am unsure how to tackle the plumbing. I'd like to use the quick connect flexible lines if possible unless that is a bad idea -- it just seems more serviceable.
The top part I think I can plumb without issues but I'm not sure how to handle the inflow side. Is that gray connector likely glued into the the white PVC? Is that PVC piece that connects to the gray piece threaded into the PVC union? It has edged sides. If so is that typically glued? It'd be great if I could avoid cutting into the vertical part. If it is glued would you bore again or just cut into the vertical line?
Thanks again-
Jason
Thanks again-
Jason
