- May 22, 2020
- 122
- Vinyl
- CircuPool RJ-45 Plus
Using a vsp so swg is inverted per instructions
Added two slip joints to remove the swg for winter
Have not glued all of it yet.
1. Does it matter where you put the Jandy valve? I assume the Jandy valves tolerate freezing temps so don’t need to remove for winter. Or I’ll put the union on the right side of the valve.
2. Pump is about 5 ft from the pool. Is that too much strain on the pvc?
On the pump side does it make a difference where to add the valve?
Shall I add it to the vertical pvc or the horizontal?
