I have a 25 year old pool. Recently my pool light turned off suddenly and tripped the GFCI. After resetting the GFCI, the pool light no longer turns on. I assume it needs to be replaced.
The pattern on the rim of the niche looks like a Pentair Amerlite. What are my options if I want an RGB light that works with my Jandy RS8 controller? Will a Pentair RGB work with the niche for the Amerlite? Will the Jandy controller be able to change the colors? I'm assuming Jandy LEDs/niches won't fit right?
Thanks!
Thanks!
