I have had this pool for almost two years, I typically just clean the cartridges, but this time I replaced them. After turning the breakers back on, I've realized the easytouch won't turn on the pumps anymore. Upon inspecting I noticed the wire in the pictures was almost all the way pulled out. So I opened the pump controller top to re attach it. I assume this is the comm wire. I can't figured out how that cable detached by me opening the filter, because I never touched it, and it all worked before replacing cartridges. The pump controller shows 0 rpms, If I push the 1-4 it works, but not at the easy touch. I have re tripped the breakers multiple times at the pump. I hit the reset button once and still same issue. Is there something else I can try? It is strange that the cable came disconnected, and now just doesn't work at all. I have a salt cell and that seems to be ok, though it says I need more salt. The booster pump that runs the waterfall still works at the easytouch. Any ideas?
