Hello all - I need to replace my Jandy Stealth pump as the bearings are failing and it is screaming when cold.
Details below on current pump
Jandy SHMP1.5
serial: J06PJ3799
Current Motor details:
AO smith
Serial 283063M
Part: 7-193993-05
PH 1
Connected to Jandy RS-8 Controller (with iAQUALINK)
Inyopool has recommended a VGreen 1.65, but it is unclear on how this would be connected to the Jandy.
Does anyone have any recommendations? I am very capable on repair / replacement, I just need to know the best option without having to replumb the whole pump. I know I need a shaft seal during replacement - are there other seals I should replace at the same time?
Thanks for any / all input.
Jandy SHMP1.5
serial: J06PJ3799
AO smith
Serial 283063M
Part: 7-193993-05
PH 1
