Remove stains from plaster pool
TurboMatt
23
Frederick Maryland
After several weeks, my pool water is finally looking good! All of the water chemical levels are excellent, per my test results and the local pool supply. Anyway, I'm now left with stains all over the plaster floor and part of the walls. What are my best options to help alleviate some of the staining without draining the pool? I would like to put off draining the pool until fall, if possible.
This is what I started with.
107994
This is how things look as of this morning.
TurboMatt
23
Frederick Maryland
Thanks for the link. I recently purchased the house and can only assume they are organic. I removed 4-5 wheel barrow full of leaves, sticks, etc from the pool when I initially opened it. So that had been sitting at the bottom of the pool for several years.
TurboMatt
23
Frederick Maryland
How high is 'elevated'?
I've also read about lowering PH levels for a week or so will help to "acid wash". The water would obviously be un-swimmable but is that a suitable option?
Mr Bruce
2,438
Greenville, SC
Somewhere between the top of your target FC and SLAM FC.
I would not recommend holding the pH artificially low for a week. Just raise the FC and they will go away. Pool Owner Patience! :)
If there are particularly "bad" spots you can put a puck on them for 15-30 minutes and it will go faster.
ajw22
11,246
Northern NJ
I am completely fine with it taking time. My concern is basically the best way to alleviate them. So if shock is around 10-12 ppm, should I plan to keep the CL around 6-8 ppm?
I would go 6-9 ppm. You want to keep FC below 10 ppm as pH test becomes unreliable after 10 ppm.
Mr Bruce
2,438
Greenville, SC
Vitamin C tablets are for metal stains, puck/elevated FC are for organic stains. Seeing that TurboMatt posted that there was leaf debris on the bottom of the pool and looking at the video, it's very very likely organic staining. Vit-C won't hurt anything to try, but I'll bet it's not going to do anything.
jimim
2,512
NE/Pa
If that worked I would do as others r saying and sit back and relax. If u leave the puck on too long u can hurt the plaster also. I would just raise the fc level. At least that way u are also keeping the pool water clean also.
