Thank you! I was going crazy trying to download and then trying to navigate the TFP site cuz I remember adding our pool to the new pool math at one time. But I figured out it was on my iPhone and I thought it would sync to my Mac.I too do not think you need to SLAM. A higher CYA may help some. But a loss of 5 ppm FC per day in your climate is not all that unreasonable.
Only backwash the filter if the pressure has risen by 25 % over clean pressure.
I do not believe the app can as of yet be put on MacBooks. Let's ask @Leebo about that.
I haven't cleaned the filter yet.....is that the problem?What is the filter pressure right after the filter is cleaned?
Also, always check your filter pressure at a mid range rpm of your VS pump, say 2500 rpm.
Well, that decision is out of my hands. The pool is my husbands new toy and his pride and joy so sadly, yes, gotta run all day at 2200 WOW factorHigh rate on the pump. Do you really want the water feature running all the time? It will drive your pH up quickly.
I run my pump at 1500 rpm because of my SWCG. You should be able to get away with 1200 rpm. With electricity cost here in Hawaii, you will use 1/4 the electricity versus now. Just run the water feature when you want the WOW factor.
