regulator vent for pool heater
stebs
126
One other thing to mention about the reg being right close to the heater. It could be that you have a 2lb gas system at your house, and this reg steps that 2# down to the low pressure the heater wants. This setup allows for smaller gas pipes between your meter and the heater. If this is the case, you likely have another reg between your meter and your house to step the house down as well.
And yes, vent points down. Some can be piped to another location, some can't.
SuzfromTexas
Platinum Supporter
3,363
Houston, Texas
Thank you, Stebs. You helped me better understand why a regulator is used or needed. Good to know. Yes, you are correct! I do have another regulator where the main gas from the street connects to my house. I sure wish I could just twirl that little ole vent to point down!
I appreciate everyone's input!! :salut:
Suz
ps0303
In The Industry
Jul 6, 2011
4,029
FL
Suz
Just get a couple of pipe wrenches and you can turn it correctly.
The dog
147
sacramento CA
Hi there. The vent for the regulator is supposed to be facing down. The regulator on my gas line is on the feeder side of the pipe before the gas company's meter.
Here's a pic
