- Sep 23, 2015
- 2,012
- Plaster
- Astral Viron V25
And for everyone using a cheap pH meter the second decimal point is only used to round up or down. Your kidding yourself if you think you can get to +/_ 0.01 pH unit.
That was a bit harsh of me. I think your likely to be close to +/-0.02 with everything else being up to standard so to speak. But for pool care that second place is good to round up or down as needed and have confidence in the result. I recall a lab prac a few years back where about 10 groups of 3 performing the same test, all using the same calibrated lab grade equipment and starting from the same master standard, all got a range of results. The results were close but some just outside of the manufacturers reported margin for error.
Traditionally TFP has avoided discussions about, and the use of digital meters for various reasons. Certainty of results for advice and sending the wrong message to those that are new to pools. But times change, TFtestkits and Taylor both sell digital meters, and I think we should be able to discuss the proper use of them. Sure, there may be occasions where those new to pools get the wrong message but we should deal with that as required and those that are new to pools will eventually be exposed to digital meters. You cant keep their little hands out of the cookie jar for ever.
