If you backwash a DE filter, you will always need to recharge it.
Coming off a SLAM, you would be best served to take the filter apart and do a full clean. You would need to add the correct amount of DE in this case too.
Fill out your signature with your pool, pool equipment (including manufacturers and model numbers) and test kit info. This helps us to help you without needing to ask for this info each time.
