So we put in a pool last year. And since then I have gone down every rabbit hole reading the endless opinions of chemistry and equipment. I have learned a lot, but at the same time also feel like I’ve just scratched the surface. My wife’s uncle pointed me in the direction of TFP so here I am. I live in central wa which is basically a dessert. Average rain fall is about 5-9” annually. Temp extremes from 0-110 degrees. But summer months let’s just say average 90’s.
We put in a 20x40 vinyl, 3.5’ shallow end 8’ deep end pretty sure, stadium steps across the shallow end, 28,800 gallons, APC automatic pool cover, 2 skimmers, 3 returns, two main drains, 4 color changing LEDS, 1.5” plumping, 1.5 hp Hayward super pump, 27” Hayward sand filter, Del uv-c 50 uv sanitation, Hayward easy temp heat pump, and a Hayward chlorine feeder for tabs. So here are some questions I have.
1. Does anyone have any set ups with UV, Ionizers, ozone, or all of them assist with chlorine or salt?
2. Lamotte ColorQ testing kits good to use?
3. Variable speed pumps? Worth it?
4. Monitoring and maintaining balance with automation and liquid feeder? Ex. Intellechecm
5. When buying bleach at 6, 10, or 12.5%, what makes up the rest of the content in the bleach?
6. Is lithium hypo better than bleach if the cost for convenience doesn’t bother me?
Thank you in advance for any help and info you all are will to share! TFP seems like a great community from what I gather.
