We have owned our above ground for 2 years. We spent too much money the last two years trying to get our chemicals correct and algae free. Our current problem--pool will hold Chlorine for only a day and then total and free chlorine went to 0. Water was milky blue. Ph, total alkalinity levels were good with stabilizer at minimum range. We shocked with 4 lbs of shock -- no results. The next day we shocked again with 3 lbs and added stabilizer. This morning levels are at the high end for all readings. Tested again this afternoon, after a day of Alabama sunshine with pump running all day and levels are still on the high end of all readings--but pool is cloudy blue with a milky appearance. What do we do?? So tired of not being able to enjoy this Pool. We have already made 8 trips to Pool store which is 50 miles away--very tired of doing that. We have flocked several times this year also. Nothing seems to work.
Help please!
24 round above ground pool
sand filter
vinyl wall finish
15,000 volume
sanitizer FROG
Help please!
sand filter
vinyl wall finish
15,000 volume
sanitizer FROG
