Thank you.The white wires on terminal A are for the clock. With that said it looks like you are are using 240v, I would have went with the t104. But you should be able to move one of the clock wires to terminal 1, and run your neutral to terminal A where you have the other clock wire. The diagram says the clock is 120v. But you should double check with Allen because I don’t know if that’s up to code. @ajw22
