I have a Raypak 406a-en-x 14 yr old NG heater.
I cleaned the burners, they are free and clear and installed a new pilot.
Heater has no error messages.
After startup, mode to pool and power on, gas on. CFH appears, SPK....a few clicks, then the gas value clicks open, and the burner ignites.
All looks normal with a strong pilot flame and all burners working.
Display shows heat flame water temp 80 and set to 90.
all good.
Heater works for hours or until temp is reached.
However, sometimes, after an hour or 2, the display shows SPK and the heater/burners ar not on/working/fired up and even though the temperature has not been reached.
It seems to be timed out. Must power off wait 5min/reset, power on and heater fires up normally.
all is good.
Any thoughts on what could be the problem?
Check pressure, ground wire, pilot wire, all good.
New pilot it's brand new replaced 1 day ago, I thought this may have been the problem.
Thanks
all good.
all is good.
Thanks
