- Sep 18, 2018
- 19
- Plaster
- Pentair Intellichlor IC-30
My Raypak heater has started to continuously cycle once fired up. The time between cycling has been intermittent but usually around 20 seconds. The heater will spark and then show “heating” on the display but then “spark” will reappear for a second and the flame will go out. This process will then continue. My spa is set to 104 and will only reach about 97 because of the frequent cycling. I’ve checked the filter and cleaned and water pressure appears fine. I’ve never needed to adjust the pressure switch since my spa is at the same level as the heater. The heater immediately cycles so I do not believe a high limit temp is being hit otherwise the heater would need to cool before cycling. Any help is greatly appreciated to get my heater back to working properly. Thank you!
