Just don't kink the tubing. Leave the coil and straighten just what you need.Hey guys, so it’s all taken apart and on closer inspection the pilot appears to be obstructed by rust.
I am ordering a new pilot and tube.
One question, is that the replacement pilot tube is 34” long, where my original is only about 12”. Does anyone see any issues with this?
Thanks again!
I’ve now taken apart the old pilot tube from the pilot. It had a bit of corrosion but I’ve cleaned it up and the tube and connections are completely unobstructed so I will try using this one first. The new 34” tube is on its way but I’ll install without that to start.Just don't kink the tubing. Leave the coil and straighten just what you need.
Just spent a long time cleaning up the burner tray as well - scrubbing with wire brushes and blowing with compressed air. There is a fair amount of rust and it’s now all completely cleaned out. No restrictions from the gas line coming from the igniter through to the top of the burners. Will keep you posted as I go. Thanks again.
