Raypack Hester Won’t Start
sagosto
122
Mahwah, NJ
When I turn the unit inn, RV1 is displayed and then SNS but no spark nor does the set point numbers get displayed. Pressing temp buttons to set display do nothing. Display sits at SNS
Where should I start troubleshooting ?
ajw22
18,959
Northern NJ
The RP2100 manual is here - https://www.royalswimmingpools.com/rp2100manual.pdf
From Raypak Heater Fault Code Guide
SNSTemperature sensor is out of acceptable range.1. Water temperature is below 36F or above 110F
2. If the two thermistors are more than 2 degrees apart, the SNS code will appear.
3. Loose or corroded connection at P1.
4. If the sensor is not mounted all the way into the JACO fitting on the header, it may give a false reading.
Temperature sensor is part 6-C on top left of page 50. It's in the heat exchanger, see page 25.
sagosto
122
Mahwah, NJ
It always displayed SNS and then go into SPK. I don’t read any troubleshooting where set point can’t be Set. Display shows set point but it’s not showing it clearly. Like Morse Code :)
ajw22
18,959
Northern NJ
How old is the heater?
Read this thread
@ps0303 may have ideas.
sagosto
122
Mahwah, NJ
I don't know age. Previous owner gave me some incorrect data regarding the pool situation. :)
I used leaf blower and cleaned out 5" of bamboo leaves on the grates and then removed the metal cover around the controller. I cleaned that area and it immediately "clicked' and started right up. I noticed a bit of moisture so I suspect it was related.
All is good. Sounds too good to be true tho.
