I think that the conclusion is that the plaster is dissolving and raising the TA and calcium hardness.
That is correct. But because I’m not in a position to replaster again after just 3 years, I need to try and maintain this disaster.I think that the conclusion is that the plaster is dissolving and raising the TA and calcium hardness.
Sounds good. So hold on adding CaCl though? Just seems unwise to add it as I'm trending +10 CH every 2-3 days.Try to keep the CSI near 0.0.
I would balance now with a pH of 7.9 to 8.0 and then lower the pH as needed as the water temp and CH climb to maintain a 0.0 CSI.
It's a difficult situation.Just seems unwise to add it as I'm trending +10 CH every 2-3 days.
Apera pH20 with calibrating solutions.Sorry I lied... Does anyone have a recommendation on a digital pH tester. There are so many on the market its hard to tell the wheat from the chaff
Yeah I may. The problem is if I add calcium now it will be high by mid late season and I’ll be back to getting new fill water every year. At $1200 not ideal. If I could at least 2 years that would help by keeping my CH downSeems easier to just add some calcium and then manage at 7.8-8.0
