Raised spa-topping off the water level
cybertoad
53
California
Hi everyone, we have a brand new pool with a raised spa/spillway. The spillway level is at mid-tile level. After using the spa and having multiple people in and out, splashing water over the spillway, etc., the water level can drop below the tile level so that plaster is showing. I typically put it into spillway mode for a couple minutes to top off the water. Is there a way to program the system to automatically add a little water from the pool periodically in spa mode to keep the spa topped off? System is Pentair Easy Touch. Thanks!
Sure. Use the Spillway function. You should be using that for 30 minutes or so a couple times a day to keep the spa chlorinated. You can schedule it. The automated valve will rotate to return the flow to the spa and suction from the pool.
Reactions: cybertoad
