I've been doing some reading of old posts regarding SWG output.
I've discovered that pump speed doesn't affect output. OK, that leaves SWG % and run time.
Pool Math tells me that my "24 hour SWG chlorine output" is .98 but what does that mean? The dropdown menu allows me to select the T-15 cell but nowhere can I find a place to record my runtime. My current runtime (8 hrs) and 10% SWG setting seems to be generating enough chlorine but I would like to know what's actually going on rather than just accepting my dumb luck. I think I'm running my pump at a higher RPM than I need. I was trying to eliminate SWG bubbles, but I've read that they are just a fact of life and won't hurt anything. (Again, I know that pump speed doesn't affect chlorine output, but since I've got you here...)
So... what does .98 chlorine output mean and which of the 2 variables should I adjust to get an acceptable target number?
(And just for the fun of it, let's pretend I don't know squat about all the abbreviations I know you're going to use )
