Questionable CYA/Slamming/Swimming
Aug 16, 2016
28
johnstown/PA
Hey all I have a "what if" scenario..
If you are not entirely sure what the cya level is..in my example Im pretty sure I can't see dot at 40ppm cya so I rounded up to 50 cya...I am slamming at 20ppm chlorine. Now say it really is 40ppm cya and I'm calling it at 50..is it safe for my family to swim at slam level I listed?
Thanks
If the FC is a bit high, there may be some eye irritation. Also fading of swimclothes. But their skin will not fall off ----
Reactions: an1vrsy
When you look at the "active chlorine" levels for SLAM Levels and compare that to what's considered safe in pools without CYA you find that "safe to swim up to SLAM Level" is a very conservative rule. Even accounting for the possibility that the CYA level might be lower than estimated due to the low precision of the test it's unlikely to be noticeable.
