It's been very hot here and a day a go I saw it, the dreaded algae on my steps. My chlorine was in range so I was surprised then I remembered that my pump was still cutting off 9pm to sunrise (sometimes I'm not that smart, I do that when it's cooler...hello it's summer). Anyway, got in it, vacuumed her good, cleaned up those dang steps, brushed the walls. And then I saw it, two of the dreaded boatmen. Below are my readings when I was done with the maintenance and boatmen freak out:
Chlorine: 3.0
CC .4 (maybe .6? it was getting dark and I wonder if I missed a tiny bit of pink, you'll see why below)
PH 7.6
TA 80
CH 80
CYA 30
Temp 88
CSI -0.53
So I slammed her. And Pool Math said 12 but I went to 18 (confirmed via testing after a couple of hours) using two full bottles of 10% liquid chlorine. Cause no, I'm not having boatmen.
This morning:
Chlorine: 15.2
CC .6
1 single dreaded boatman still hanging around those steps. And I can't get them out alone, I wonder about behind them. I wonder if I should just replace them (5 years old) and I cannot see behind them to save my life. Maybe it's best to get a pool company out to pull them, clean them, put them back in? I had them out to re-tape my hard pipes from pool to filter early in the year and replaced my sand. Nice folks, reasonable pricing.
I assume I am on the right track but with my HIGH chlorine numbers do I add more today? Or just let it ride? Also I was hoping for it to be gone over night since my CC isn't that high but nooooo. I know CYA needs to come up a tad but should I wait until after SLAM?
I also popped a 8 oz floater tab in there. Ingredients:
Thanks for your help with this. I've so rarely had an algae issue that I'm surprised and a bit concerned.
Chlorine: 3.0
PH 7.6
TA 80
CH 80
CYA 30
Temp 88
CSI -0.53
This morning:
Chlorine: 15.2
CC .6
- 99% Trichloro-S-Triazinetrione
- 1 % "other"
